Different SidePanel at each page - possible?
Different SidePanel at each page - possible? was created by kazamason
Hello!
I'm looking for a module just like this and your product seems to be exactly what I need for my side.
Before I purchase, I'd like to find out will I be able to customize it for my site's needs:
I will be having a lot of informational articles on my site and would like to use a slide-out module on the right side to display additional information for that exact article.
So, that will be:
- the sliding panel is always in the same position
- there is only one sliding panel on each page
- the content inside the sliding panel is different depending on what page it is
Is this possible to do with SidePanel JT1?
And if it is - how would you recommend to do it?
Thanks in advance for your replies.
So, that will be:
Replied by admin on topic Different SidePanel at each page - possible?
Hello thanks for interest
(For this you should duplicate module each time and publish only what page is needed.That may require to create a menu item for each page.Each module should be published on the same side of the page of course)
(That will be possible by duplicating module each time and publishing only the page needed)
(You should enter each extra content manually for each module or you should create a custom html module for each content and call it inside sidepanel JT1. Side panel module has 2 options 1-You can publish any module inside sidepanel module 2-You can manually enter your content
Time to create page: 0.402 seconds
COM_CONTENT_ARTICLE_HITS
Horizontal Accordion JT1
Habernews Joomla News and Magazine Template
WT Corporate Business Joomla Template
