SidePanel Instances
Another "drawer" module I was using used css for the tab title which could be customized in the module settings. Since the SidePanel went the route of using an image for the tab, only 1 title has to be used for ALL instances of the module on the site.
Since I am using it for the login/logout module, it is weird to always have it say "Login" even when already logged in. With the previous module, I simply had two modules, one login, the other logout, and I would deactivate one or the other depending on the users registered state. The was very useful.
With all that said, I would like to do the same. I saw jt2, but from the description, it appears it does not have the top option. Also, it would be terrible to have to pay double to use a module twice.
Can you think of a workaround where I could use the module with different tab titles? If not, would it be unreasonable to ask to create an identical copy of JT1 as JT1b or something of the sort so that this can be accomplished. (Honestly, it would make the product much better to have the tab be css so it can be customizeable within the options, rather than having to replace image files, imo.
help appreciated.
regards.
any problem?
Amitza Joomla News and Magazine Template
Habernews Joomla News and Magazine Template
Carousel JT1
Horizontal Accordion JT1
Content Captions JT
Eranews Joomla News and Magazine Template
