Problem with scrolling
- SadruddinW
I've now installed JT1 Scroller, again, having given up on it a couple of weeks ago.
What I want to do is scroll the content of an article. Simple as that.
I like the way the demo works, but I don't need to go up a few lines and stop, just to slowly scroll up, pause, and then start again.
My problems are:
1) I can't seem to find any documentation
2) I can't find anywhere to name (or number) an article
3) If I enter text it all collapses and runs together with no line breaks or paragraph breaks.
4) At the default setup it rushes up nd then starts again
5) I changed it to scroll speed 15, and it sits and then sort of blinks.
www.itsmyheart.co.uk/site/index.php?opti...icle&id=7&Itemid=119
- SadruddinW
- SadruddinW
Now your questions
There is no obligatory rule determined by joomla extensions directory officials on submitting an extension (free or paid). So I do not have to to provide any documentation If I do that is totally up to me.
You should name or number your manually entered text. The manually entered text feature is only active on free version.
That is related to your template's css and paragraph codes.
I did not understand this??
your extension does not work it seems a jquery conflict. First try to disable jquery on module settings. If does not work than install easy jquery plugin and publish it with right settings.
- SadruddinW
I certainly didn't intend to be.
I'll check your solution.
Eranews Joomla News and Magazine Template
Carousel JT1
Content Captions JT
